A rich espresso finish enhances this stylish sliding door media cabinet. Each door slides open to reveal the spacious and versatile interior. While the top, center and bottom shelf are fixed, 4 adjustable shelves combine to create unlimited options for your media storage. Window paned sliding doors, adjustable shelves, and contemporary elegance all combine to create an excellent addition to your home. - 31.75-Inch W x 9.25-Inch D x 48.75-Inch H - All shelves are 28-Inch W x 5.75-Inch D - 3 fixed shelves - 4 adjustable or removable shelves for maximum flexibility - 3 inch increment choices for adjustable or removable shelves - Distance between the top of the unit and fixed shelf #1 - 5-Inch - Distance between fixed shelf #1 and fixed shelf #2 (center shelf) - 16-Inch - Distance between fixed shelf #2 (center shelf) and fixed shelf #3 - 16-Inch - Distance between fixed shelf #3 and bottom of the unit - 4.75-Inch - Contemporary Espresso Finish - Tempered glass doors - Holds up to 248 DVDs or 536 CDs - Assembly required Southern Enterprises - MS1071T
Bellacor | [show price] |
World Market | [show price] |
