- Beauty-Mark brand Maui-LX model motorized retractable awning - Manual over-ride motor with remote control. Right motor when facing the awning - 8' wide x 7' projection or depth with adjustable pitch - Multi chamber arms with stainless steel cables - Structural steel and aluminum frame, powder coated in white - Fade, mildew, water resistant 100% solution dyed acrylic fabrics - 10 Sahara style valance with off-white trim - Fully assembled, ready to install and comes with the wall brackets - 5 year limited warranty - Product Depth: 84 - Product Width: 96 - Product Height: 10 - Product Weight: 75 - Material: Fabric - Minimum Mount Height: 96-in - Minimum Required Clearance: 10-in - Includes Fully assembled awning, product manual, rocker arm, wall mount brackets, and remote control Awntech Corp - MTR8-60-B
