The Diamond Bravo Two is the worlds best-selling aftermarket prop. These durable aluminum blades are used as standard replacements on many motor models and are excellent for boaters looking for improved mid- to top-end performance. Made from an exclusive aluminum alloy that resists corrosion. Ideal for most outboard and sterndrive models up to 250 horsepower and speeds up to 50mph. This propeller uses the Quicksilver Flo TorQ Hub System, so you can easily switch props, change pitch, change from aluminum to stainless, or replace a bent propeller. Vendor Part Number: 48-8M0078089A Material: AluminumA No. of Blades: 3 Diameter: 19.25"A Pitch: 15" Rotation: Left-HandApplicationsMERCRUISER4.3L 155-250 hp (96 Newer) 5.0L 180-250 hp (95 Newer) 5.7L 210-300 hp (93 Newer) 6.2L 320 hp (01 Newer) 7.4L 300-385 hp (90 Newer) 454 385 hp (96 Newer) .
Overton's | [show price] |
Gander Mountain | [show price] |
